Sun Warps Siding (window Magnifies) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-26-2011, 12:23 AM   #1
Sun warps siding (window magnifies)
I am having a problem with vinyl siding on two locations on my house. One on the north side. One on the South side. It is caused by the morning and evening sun light reflecting off windows and hitting the siding.
I can actually watch the focused light traverse across the siding.
The end result is the siding is warped and "almost" melted on an angled patch of siding 4 feet high, and 6 inches wide.
I can address this on the South side by planting a tree, but the North side is happening on the second story.
Any suggestions?
RainWaterEyes is offline   Reply With Quote
Old 08-26-2011, 06:37 AM   #2
kwikfishron's Avatar
Rewards Points: 176
Replace your siding with a product that doesn’t melt.
kwikfishron is online now   Reply With Quote
Old 08-26-2011, 06:53 AM   #3
Unfortunately certain brand and especially colors (Natural Clay, Savanna Wicker) have a tendency to melt down in conditions you mentioned. I've tried to find a cure for many years, stuffed underlayment with foam, etc. Nothing worked so far. Try make a screen for that window, get reflection ability lower.
chstan is offline   Reply With Quote
Old 08-26-2011, 07:00 AM   #4
Rewards Points: 176
What are you suppose to do when itís the Neighbors windows thatís melting your house?
Old 08-26-2011, 11:29 PM   #5
Registered User
Rewards Points: 5,212
It's been a problem for years, try researching further for a solution: http://www.google.com/url?sa=t&sourc...1vk4U3c5XIx76A
http://www.wcnc.com/on-tv/Melting-Vi...-83583357.html
Gary
Old 08-27-2011, 08:00 AM   #6
Tom Struble's Avatar
Rewards Points: 2,002
Ron,i bet alot of finish problems on other types of sidings are being damaged by this and being attributed to water intrusion or product failure
Tom Struble is offline   Reply With Quote
Old 08-27-2011, 04:36 PM   #7
Rewards Points: 176
You could very well be right.
Other than a few pictures on the net I’ve never seen this before. I wonder how hot the light is actually getting to melt the siding and how narrow, focused and hot it’s capable of. Is this a reflection from the low-e or what?
Old 08-27-2011, 04:51 PM   #8
Rewards Points: 176
Gary
Interesting thread you linked. I had no idea how common this is. I guess I’ve just spent to much time on the foggy/cloudy coast.
Old 08-27-2011, 08:52 PM   #9
Registered User
I found another 1/2 dozen complaints about a year ago, kept the better ones. Near Mt. Rainier in WA, a smaller City had similar problems, also. Haven't heard much lately..... maybe the window company went under.
Gary
Old 09-01-2011, 01:36 AM   #10
Here is a photo of my problem.
This is the south side of my house. North side has the same problem with an upstairs window affecting another bump out.
Thanks for links and for taking an interest in the problem.
Tags
melted , siding , sun , vinyl , warp
Window casing around j channel on existing siding zacharyw Remodeling 9 11-21-2010 09:42 AM
Drip Cap necessary if there's no siding above window? toolingaround Building & Construction 7 10-25-2010 09:53 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Window Replacement and siding over T-111 and thick felt board Badger Hill Building & Construction 4 05-04-2009 09:27 PM
Adding a window - cutting through Aluminum Siding -how to repair siding to look good? DyerWolf Building & Construction 6 12-22-2008 05:02 PM
