Sump Pump Liner - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 10:15 AM   #1
sump pump liner
I have a 12 yr old home with a plastic sump liner installed, but no pump. The sump filled 2 yrs ago and I used a portable pump with a float switch to empty it. I left the pump in and it runs a couple of times a year. I wish to install a permanent pump prior to radon remediation. There is one 4 in tile which enters the liner at about the median point. There is 3 in of water in the sump. There are no other perforations in the liner. It looks like water enters from around the 4" tile. Do I need to perforate the liner to allow water (and air for radon) to enter freely?
Rlueck is offline   Reply With Quote
Old 04-06-2012, 10:33 AM   #2
Experienced
Jackofall1's Avatar
Did you test positive for Radon?
I wouldn't perforate the liner, thats will just put dirt in your sump. If the tile is doing its job you wouldn't get any more out of the ground than you already are.
Mark
Old 04-06-2012, 11:46 AM   #3
Concrete & Masonry
Rewards Points: 568
It's not uncommon for the water to enter below the 4" tile, as it's likely well-perculating stone around the pipe & crock, and the holes aren't an exact fit to the pipe as they don't need to be. As a general rule, I don't like ot see water any higher than at least 8" below the floor. More is better. It sounds like you're stays far below that, which is great.
Can't comment on the radon question though.....
jomama45 is offline   Reply With Quote
Not your normal sump pump question..(electrical) windowguy Electrical 13 10-03-2011 01:17 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 07:55 AM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
looking to upgrade sump pump coeng Plumbing 14 06-04-2007 03:08 PM
