Sump Pump Basin Cover - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-24-2010, 10:44 AM   #1
Rewards Points: 640
Sump pump basin cover
My current sump pump / basin has one of those cheap plastic covers that just has a slit down it... not sealed up...
is there anyway to replace the cover or get one of those ones that is basically sealed with a hole for the pipe only to replace it? or does the whole sump basin need replaced somehow?
BlueBSH is offline   Reply With Quote
Old 06-24-2010, 02:04 PM   #2
Rewards Points: 5,336
Why does it need to be sealed up? Kids/pets falling into it?
Ron
Old 06-24-2010, 02:33 PM   #3
Rewards Points: 640
Ron
Humidity created by the water just sitting there... the bugs crawing out of it... etc...
I drew a circle around it with Ortho bug defense (i think it was) and you should see the tons of critters that came out of it and died right after going over the line of death
also helps deaden the noise of the pump running
Old 06-24-2010, 02:43 PM   #4
Rewards Points: 6,652
If you are getting a lot of bugs, etc, call an exterminator, and they can look at the situation. The cover you are thinking, is the type used for Radon mitigation.
Old 06-24-2010, 02:59 PM   #5
Rewards Points: 640
Ah, ok... wonder why they put those covers on my negibors houses... for some reason mine doesnt have that type but they do and none of us have a radon mitigation system in place
Old 06-24-2010, 07:14 PM   #6
http://www.thisoldhouse.com/toh/arti...195703,00.html
http://www.toppindustries.com/
Old 06-25-2010, 03:04 PM   #7
Rewards Points: 4,538
sheet plastic & a tube of silicone seal - VOILA ! ! !
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump Basin Install Considerations Fire4Effect Building & Construction 3 08-05-2009 05:30 AM
need to build something to cover my sump pump bowanna03 Carpentry 3 04-07-2009 01:08 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
