-   -   Sump pump basin cover (http://www.diychatroom.com/f19/sump-pump-basin-cover-74529/)
BlueBSH 06-24-2010 09:44 AM
My current sump pump / basin has one of those cheap plastic covers that just has a slit down it... not sealed up...
is there anyway to replace the cover or get one of those ones that is basically sealed with a hole for the pipe only to replace it? or does the whole sump basin need replaced somehow?
Ron6519 06-24-2010 01:04 PM
Why does it need to be sealed up? Kids/pets falling into it?
Ron
BlueBSH 06-24-2010 01:33 PM
Ron
Humidity created by the water just sitting there... the bugs crawing out of it... etc...
I drew a circle around it with Ortho bug defense (i think it was) and you should see the tons of critters that came out of it and died right after going over the line of death
also helps deaden the noise of the pump running
gregzoll 06-24-2010 01:43 PM
If you are getting a lot of bugs, etc, call an exterminator, and they can look at the situation. The cover you are thinking, is the type used for Radon mitigation.
BlueBSH 06-24-2010 01:59 PM
Ah, ok... wonder why they put those covers on my negibors houses... for some reason mine doesnt have that type but they do and none of us have a radon mitigation system in place
gregzoll 06-24-2010 06:14 PM
http://www.thisoldhouse.com/toh/arti...195703,00.html
http://www.toppindustries.com/
stadry 06-25-2010 02:04 PM
sheet plastic & a tube of silicone seal - VOILA ! ! !
