Old 08-21-2012, 10:37 AM   #1
sump pump airtight lid question
I'm installing a new sump pump in a crock with an airtight lid. I believe the lid has 2 holes, one for the water discharge pipe and one for an air vent pipe. I assume that without a way for air to get into the crock, the pump wouldn't be able to pump the water out because it would create a vacuum effect, correct?
The main reason I'm asking is because I don't want to have to run 2 PVC pipes and drill 2 holes in my rim joist if I can avoid it. I'm sure I could just leave the one hole (for the vent pipe) open but then there's a radon risk.
DIY1 is offline   Reply With Quote
Tags
sump pit, sump pump
Sump pump help jazzyj Plumbing 10 09-12-2011 08:55 AM
understanding the numbers on a sump pump and which one to buy ksimpson Plumbing 0 09-09-2011 08:51 AM
Sump pump capacity question Davidb6 Plumbing 6 02-22-2011 10:17 AM
sump pump question moisheh Plumbing 1 09-13-2009 03:14 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
