Sump Pump - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 01:27 PM   #1
Sump Pump
I am trying to buy a house and just noticed there is a sump pump in the basement. I do not know anything about this pump. Do you think it is a good idea for me to buy this house?
rbhamjee is offline   Reply With Quote
Old 11-15-2011, 02:27 PM   #2
Msradell's Avatar
Rewards Points: 84
Having a Sump Pump is certainly not a bad thing in most cases, it's actually a good thing. Having it means that the builder took precautions to ensure the water did not penetrate into the basement. If you can check out the house soon after it rains heavily, if the Sump pump is running constantly or almost so there may be a problem but otherwise it's certainly nothing to worry about. If it's running on a regular basis when it's dry and has been so, run, don't walk away from that house.
Msradell is offline   Reply With Quote
The Following User Says Thank You to Msradell For This Useful Post:
rbhamjee (11-16-2011)
Old 11-15-2011, 10:06 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
take a good look around the floor and walls in the basement to see if there has been any recent flooding in the basement. You can usually tell. Sumps are completely normal to have in a basement and are usually planned into the building of the house.
Millertyme is offline   Reply With Quote
Old 11-16-2011, 07:28 PM   #4
Thank you for your advise. I did not get a chance to see the pump running but when I removed the lid it is full of water. The basement floors and the walls are very dry. There is no sign of wetness any where.
Old 11-19-2011, 11:23 PM   #5
Milwaukeetool's Avatar
Sump Pump
see below
Milwaukeetool is offline   Reply With Quote
Old 11-19-2011, 11:24 PM   #6
Sump Pump
Not a bad idea to either have a battery back-up or generator for any sump pump. Power tends to be lost in storms, and storms bring water.
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump pump help jazzyj Plumbing 10 09-12-2011 08:55 AM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
