Suggestions For Wall Anchors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-06-2006, 07:48 AM   #1
Malibu Mike
MIKEGOUGH1's Avatar
Suggestions for wall anchors
I am building a 24 x 24 garage in my backyard on an existing slab. I will have a 16' garage door and 1 entrance door. The slab does not have
anchor bolts in it, so I am going to drill holes and install anchors. What type of anchors should I use, and what size should I use, 3/8", 1/2" or 5/8"? How far apart are they usually placed?
MIKEGOUGH1 is offline   Reply With Quote
Old 12-06-2006, 09:23 AM   #2
General Contractor
joasis's Avatar
I would use at least 4 inch long wedge anchors....1/2 inch at a minimum, spaced 5 feet on centers on the walles and one next to the jambs on every door. 3/4 inch anchors would be better, and the few bucks you spend on these is well worth it. I prefer red head anchors, not the cheasy cheap ones.
joasis is offline   Reply With Quote
Wall Anchors ffgus Electrical 3 10-17-2011 11:16 AM
Requirements for Sill anchors and ledger boards? sandyman720 Building & Construction 7 08-20-2007 06:56 AM
Hip Vents for 12/12 pitch roof - any suggestions woodworker2000 Roofing/Siding 5 10-26-2006 10:31 AM
