Suggestions On Rebuilding Load Bearing Wall - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-28-2009, 05:35 PM   #16
Rewards Points: 159
I have this area that has my furnace exhaust and AC lines.
This is the spot I would really like to put a small door in, for my future wine cellar.. I need to see what the max height of a door would be!
Maybe I can frame this high enough for a door and be able to clear the pipe.
theedudenator is offline   Reply With Quote
Old 12-28-2009, 05:38 PM   #17
Rewards Points: 159
From the cement floor to the pipe is 79"
Doesn't seem like enough room for a standard height door.
I will have to see if i can get a door that is shorter? Or cut one myself.
Old 12-28-2009, 05:45 PM   #18
Framing Contractor
Go to a real lumberyard and they will cut you a door to whatever height you need.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-28-2009, 05:46 PM   #19
Rewards Points: 159
What would you suggest a real lumber yard is?
I only have Menards, Lowes and Home Depot close to me...
Old 12-30-2009, 07:14 PM   #20
Rewards Points: 159
I chickened out and just built the wall on the ground.
The joist to floor was actually pretty level.
Old 12-30-2009, 07:15 PM   #21
Rewards Points: 159
Is this what I need to do now on the top and bottom? To secure it?
Old 12-30-2009, 07:29 PM   #22
That's what I do
I sometimes use a screw or 2 to hold it in place while I hammer in some nails
Old 12-30-2009, 07:39 PM   #23
Rewards Points: 159
Since I wanted this to take the load, the joist was jacked up a bit.
Then lowered down when I had it in position. So it is now taking the load of the joist along with the 2 poles.
Old 12-31-2009, 07:49 AM   #24
Sounds like you've got things going well!
If you have a Habitat for Humanity Resale Store or another place that sells used construction materials you can probably buy an old solid wood door for $10 or $20 and then cut it to whatever height you want.
If you get a hollow core door, you use a chisel to separate the bottom strip from the skin and pull it out, then cut it off and put the strip back in place with glue and clamps.
pyper is offline   Reply With Quote
Old 12-31-2009, 09:12 AM   #25
Rewards Points: 159
I have never seen a used supply shop in my area. Maybe I need to pull the phone book out.
An old beat-up refinished door would look good for the wine cellar!
Load Bearing Wall- In wall Fish Tank cmh1027 Building & Construction 13 01-08-2010 05:20 PM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 05:31 PM
Sister joist and load bearing wall Daniel048225 Building & Construction 2 09-21-2009 09:33 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 03:44 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 07:37 AM
