Suggestions On Rebuilding Load Bearing Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-25-2009, 10:40 PM   #1
Rewards Points: 153
Suggestions on rebuilding load bearing wall
This is a hard one to describe, so I will try to keep it to the facts - not why the previous owner did the damage.
I have an old sill joist that is no longer on the edge of the basement (basement was extended out 8 feet)
So I have this joist 2x8" running east/west.
Then there are standard spaced floor joists running from the south side and north side. When I had the house inspected it was put on my list of things to correct. I was told me options were to double/triple up the existing 2x8 to make it sturdy, or replace the wall that was removed from below.
It happens that I want a wall where it was removed (furnace room)
So do I build the wall on the floor and try to beat/bang it in place?
I was told I need to do it this way in order to avoid toe nailing all of the studs.
Or just build the wall as I go?
I doubt the old cement sill on the floor is still level..
theedudenator is online now   Reply With Quote
Old 12-25-2009, 10:49 PM   #2
DIY staff
Rewards Points: 7,174
I think I'd 'stick build' it.--Building it in place will allow you to cut the studs to the length needed.
You are right to assume that the floor is going to be uneven. Toe nailing is not the end of the world.
It's easy for me to say-HaHa-I've got a nail gun! Seriously even hand nailing one wall is not to big of a job.
Have fun-be safe --MIKE--
Old 12-25-2009, 11:00 PM   #3
Rewards Points: 153
I could borrow the proper nail gun.
But this is only going to be about 4 studs total.
I was planning on treated lumber for the bottom.
Then tapcons installed with my rotary hammer.
When the supporting brick wall was removed, 2 steel support pipes were added, I am going to leave those in place.
Old 12-25-2009, 11:11 PM   #4
firehawkmph's Avatar
Rewards Points: 1,822
Borrow a nail gun for four studs? C'mon, get the ol hammer out. Toe-nailing is good for you. It wasn't that long ago when I used to do a lot of toenailing by hand, every time we set trusses. You are going to cutting the studs for a tight fit anyway. Tap each one into place, put your foot on the opposite side of the stud as a doorstop, and drive your nails. Pound a couple more in from the other side and move on. You can be done before you even drag a compressor down the stairs.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 12-25-2009, 11:24 PM   #5
Rewards Points: 153
Ha! I said I could...
What about the treated lumber and tapcons for the bottom plate?
Then I would nail another plate into this?
Old 12-25-2009, 11:37 PM   #6
Rewards Points: 161
Dont forget that any nail driven in the pressure treated wood should be heavy galvanized or stainless steel nail.
paul100 is offline   Reply With Quote
Old 12-26-2009, 07:47 AM   #7
DIY staff
Definitely use treated bottom plate. Tapcons are fine--MIKE--I've never used galvanized nails on interior framing into treated plates--Never had a problem?????????????? Learn something new every day-Mike-
Old 12-26-2009, 09:18 AM   #8
Framing Contractor
OMG!!!Who told you that? Sounds like a 90 year old grandma. It amazes me how people are scared or want to avoid teonaling a stud. Even some pros out there will try to avoid it. I've been toenailing studs for over 25 years. It's not rocket science and there's nothing to it even the first time you do it. Any kid can toenail a stud.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 12-26-2009, 01:39 PM   #9
Registered User
Rewards Points: 5,216
"So I have this joist 2x8" running east/west.
Then there are standard spaced floor joists running from the south side and north side." ---------- I would fix this ASAP. If supporting one floor, roof and ceiling, 2x4 studs at 16"o.c. are required. If supporting 2 floors, roof and ceiling, 3x4's OR 2x6's at 16" are required per code. Here is some help on toe-nailing: http://books.google.com/books?id=_CP...age&q=&f=false
Hope this helps..... Don't feel bad, we all started sometime, well, most of us.
Be safe, Gary
Old 12-26-2009, 03:32 PM   #10
Rewards Points: 153
I have cleared out the old brick and mortar leftovers to provide a flat surface for the treated 2x4's
I decided to round the corner and build a complete wall
Old 12-26-2009, 03:35 PM   #11
Rewards Points: 153
These are photos of the joist I am going to add support.
Note the area with 3 joists sistered together. this is butted to a single joist. This should have been sistered also, but instead I am going to build a load bearing wall under it.
Old 12-27-2009, 01:30 PM   #12
Rewards Points: 153
Thanks! I let my Dad know he is a really a Grandma...
This was actually due to my lack of coordination with a hammer.
I typically drill and screw everything I can.
Old 12-27-2009, 02:04 PM   #13
Framing Contractor
No offense to your dad, but tell him that there's nothing to it when toenailing. If you lack coordination with a hammer there's really no difference between toenaling and facenailing, it's all in your wrist. You have four studs to nail, it will be fun.
Joe Carola
Old 12-27-2009, 02:29 PM   #14
Rewards Points: 153
If he was doing it he would toe nail.
Since I am doing it he suggested that I take steps to avoid toe nailing...
Either way, I need to buy some studs and nails and see how it turns out!
Old 12-28-2009, 06:33 PM   #15
Rewards Points: 153
I starting putting the tapcons in... and my only bit broke... so I got them started anyway.
And some pics of putting in spacers on the top to clear the gas lines
Load Bearing Wall- In wall Fish Tank cmh1027 Building & Construction 13 01-08-2010 06:20 PM
Can't tell what to do with this wall, load bearing?? fox_forma Building & Construction 22 09-26-2009 06:31 PM
Sister joist and load bearing wall Daniel048225 Building & Construction 2 09-21-2009 10:33 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
