Suggestions Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2011, 11:57 AM   #1
Suggestions Needed
I have a deck that leads from my kitchen on the second story, I would like to enclose it to expand my kitchen
Alcarte is offline   Reply With Quote
Old 02-05-2011, 12:03 PM   #2
Experienced
Jackofall1's Avatar
Sounds like a kitchen on the back of walk-out house, correct?
There a few different ways you could accomplish the addition, all of which would require foundation mods.
Old 02-05-2011, 12:46 PM   #3
Rewards Points: 5,336
Is there a full basement under this structure? Does the foundation differ under this part of the house as oppossed to the rest of the house?
If the foundations are the same, I see no reason the foundation would need to be modified. But when you file plans you should be getting some guidance from the architect and the building dept.
Ron
Old 02-05-2011, 12:51 PM   #4
Experienced
Jackofall1's Avatar
If the foundations are the same, I see no reason the foundation would need to be modified. Ron
When was the last time you saw a full basement under a deck?
Old 02-05-2011, 01:48 PM   #5
It's a Carport located underneath the Deck supported by concrete slab
Old 02-05-2011, 02:04 PM   #6
And of course wood post
Old 02-05-2011, 02:09 PM   #7
Experienced
Jackofall1's Avatar
Well the first place I would start, other than here that is, would be to contact a designer and go over with that person what exactly it is you are trying to accomplish.
With that information draw up a set a plans, and then meet with some contractors.
Given the information that you have shared with us, I would say you will need foundation work to start with.
Mark
Old 02-05-2011, 02:18 PM   #8
Thanks Mark
Old 02-05-2011, 02:20 PM   #9
Framing Contractor
This type of addition is done alot. You have to have an architect or engineer come in and see if the existing deck, beam, ledger, posts and footings can handle the addition. Depending on which way the roof runs, that's another thing that has to be figured out. If it will be a gable roof or a shed roof.
Joe Carola
Joe Carola is offline   Reply With Quote
Suggestions for a Studio Apt. PNYCB Interior Decorating 10 01-24-2010 03:59 AM
Color suggestions? kevinc Interior Decorating 2 01-04-2010 04:41 PM
Furnace Fan is loud...suggestions needed robmypro HVAC 5 09-28-2009 04:22 PM
Hose holder suggestions needed diyntn Landscaping & Lawn Care 5 06-27-2009 03:12 PM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
