Suggestions/Advice on water into track of sliding glass door causing carpet damage
While we can't see under the threshold, my bet is there is no pan under it. If your carpet is rotten, most likely if there is no pan, you will have some damage under the door also.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
