Is It Suggested: Turtle Vents With Ridge Vents??? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-20-2012, 08:00 PM   #1
Rewards Points: 150
Is it suggested: turtle vents with ridge vents???
Recently, I was told that having turtle vents installed with ridge vents is considered good or "over-ventilated".
I just want your opinions about this...
Please share your thoughts and recommendations!
Thank you in advance.
oodssoo is offline   Reply With Quote
Old 08-20-2012, 08:05 PM   #2
Rewards Points: 12,812
You only need soffit and a ridge vents.
Looks better and vents the whole roof not just a circle, uses no power and should be 0 maintance if there not a hurricane.
Old 08-20-2012, 08:07 PM   #3
Rewards Points: 150
Is "over venting" accurate?
Old 08-20-2012, 08:20 PM   #4
the Musigician
DangerMouse's Avatar
Sometimes, ridge vents are not installed correctly and therefore do not work as well as they should. I've seen extra vents added to compensate for this.
DM
Old 08-20-2012, 09:19 PM   #5
Haverhill Trade 1965
Another problem is if the wind blows into them it can reduce the airflow you have. Most info I have seen is one or the other with soffit vents. Use with ridge, roof, or louvers not any combination the three.
Duckweather is offline   Reply With Quote
Old 08-23-2012, 10:07 PM   #6
Rewards Points: 150
Thanks, guys!
A local builder made the suggestion that by having ridge vent AND 6 turtle vents will be better and over ventilate... Further, he even said that it would be best to over than under ventilate...
I am curious to know of more of your inputs... and opinions...
thanks.
Old 08-24-2012, 01:01 PM   #7
Registered User
Rewards Points: 4,912
You don't want more exhaust vents than intake or the condition house air will exhaust to make-up, use a baffled ridge vent; http://books.google.com/books?id=Z8a...0vents&f=false
Air seal the attic first and foremost; http://www.google.com/url?sa=t&sourc...wWATQw&cad=rja
The "stack effect", natural or forced will drive the attic exhaust along the sheathing above; http://www.wag-aic.org/1999/WAG_99_baker.pdf
I would leave the turtles alone, you want enough exhausts but not too many, as said already; http://en.allexperts.com/q/Roofing-1...able-Vents.htm
As long as they are 3' higher than the soffit intake vents, they would function as exhaust vents; http://www.finehomebuilding.com/desi...ble-vents.aspx
The NFVA differs greatly per manufacturer of the ridge vents, be sure to add the turtles as exhaust when figuring your percentage split; http://www.airvent.com/homeowner/pro...it-specs.shtml
Gary
Knee wall w/ soffit vents no ridge vent -- seal soffit vents? tblaz Roofing/Siding 1 04-24-2011 05:12 PM
Ridge vents? klab Roofing/Siding 7 06-28-2010 03:05 PM
Ridge vents and roof vents jerry1967 Roofing/Siding 4 06-07-2010 06:40 PM
Ridge vents and/or fan? mama2girls Roofing/Siding 20 05-27-2009 08:12 AM
Attic Insulation - Current R Value? jamiedolan HVAC 37 01-01-2009 12:03 PM
