Subflooring For A 24X60 Mobile Home It Has Dry Rot In Some Spots It Looks To Be Soem Type Of Pressed Wood Material ,what Would You Suggest For Replacement? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-28-2010, 03:27 PM   #1
what type of material to replace sub flooring on a 24X60 mobile home ? the current material seem to be pressed wood of some type that is about 5/8" thick
hello im trying to get you response
Might want to wait more then 3 minutes before bumping your thread
Moderator
rayfogleman is offline   Reply With Quote
Old 05-28-2010, 04:03 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
it is probably 5/8'' particle board. Some folks will use OSB. Personally, I prefer plywood. Whatever you use, it needs to be exterior grade to resist moisture.
Old 05-29-2010, 12:23 AM   #3
Cut the damaged section out with a jig-saw. Cut two pieces of 1X3 wood, 3" longer than than the opening is wide.
Slip the 1X3's into the underside of the opening and screw them in place with deck screws. (drill pilot holes)
Make a replacement patch from some plywood, using the section that you cut out, as a pattern.
Caulk the patch around the perimeter and drop it into the opening.
Using deck screws, screw the patch onto the 1X3's.
It would be a good idea to glue everything before screwing the pieces together.
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 03:59 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
