Subfloor / Sole Plate - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-16-2013, 06:55 PM   #16
Rewards Points: 31
Joe, I was wondering what you recommended for attaching that ledger. I'm figuring the blocks are hollow and I've seen a ton of different concrete anchors. I've heard of expansion anchors with adhesive and all kinds, so just curious.
Outdoorbum is offline   Reply With Quote
Old 12-17-2013, 09:42 AM   #17
Rewards Points: 12,812
I'd use these.
http://www.concretefasteners.com/anc...teners/sleeve/
Old 12-19-2013, 06:24 PM   #18
Rewards Points: 31
One last question gentlemen; with an only 1 1/2" wide ledger, what would I use to attach the joist hanger to the ledger given there is concrete behind it?
Thanks!
Old 12-19-2013, 07:05 PM   #19
cortell's Avatar
Rewards Points: 504
Thanks!
1-1/2" common nails. Box stores here usually place HDG Simpson nails right next to the hangers. Keep in mind you need to either use PT lumber or put a vapor retarder between the concrete and lumber.
cortell is offline   Reply With Quote
Old 12-20-2013, 08:06 PM   #20
Rewards Points: 31
Ok thanks. Plan on using PT ledger
Old 06-07-2015, 12:44 PM   #21
Rewards Points: 31
Hey guys , back after a long absence after some personal tragedy so thought I'd set the record for longest running thread . If any of you are still around , wondering if adding a vapor barrier behind even PT lumber for my ledger would be a good idea , and what to use and how . Should it be just the size of the ledger or have good overlap ?
Thanks everyone. Hoping to get diy going again in my life as a form of therapy...
Old 06-07-2015, 08:12 PM   #22
If it was me..
I would just add bridging under the 2 by bottom plate for the wall and call it a day...
ron45 is offline   Reply With Quote
Old 06-10-2015, 02:28 PM   #23
Rewards Points: 31
I hear ya, but I think I'm going with a ledger and was thinking about tar paper behind it. I don't know, I'm sure PT lumber against the CMU will be fine but just thought an extra waterproof layer couldn't hurt right behind the ledger. If it causes a water trap then thats what I'd want to avoid....I just want this to be one time deal so any suggestions are great.
Sill plate, sole plate, bottom plate -- please "un"-confuse me. Dave88LX Building & Construction 25 12-04-2013 08:30 AM
Replacing sill plate - foundation wall repair NWChris Building & Construction 0 09-14-2013 01:05 PM
Jacking Exterior Wall / Replacing Sill Plate Pittsville Building & Construction 2 06-16-2012 10:11 AM
HELP PLEASE replacing rotted sole, top and bottom plate dolson Remodeling 4 04-16-2010 07:54 PM
Replacing Section of Sole Plate RM575 Carpentry 3 03-28-2010 10:31 AM
