Subfloor Repair Around Toilet? - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-03-2011, 10:02 PM   #16
I am adding joists to the shower right now. My question is about the toilet area. As I've looked at the existing flange and piping, everything looks in very good shape. As I said reinforcing under the toilet is going to be very hard because of HVAC ducting right under the floor making adding cross joists impossible. It seems that anything I do to try and cut and replace, it won't be as strong as the existing subfloor (since the present subfloor spans multiple joists and goes under the walls.
I was considering instead perhaps I could just run the new layer of 5/8" ply over the existing subfloor around the current toilet flange and add a flange extender? It seems like as far as the strength of the floor this might be optimal?
bernieb: Sorry I miss spoke, trap was under the shower, not under the toilet.
bob22: never considered putting masonite just 5/8 acx.
Thoughts?
B
b_corwin is offline   Reply With Quote
Old 02-04-2011, 04:14 PM   #17
Registered User
Termite's Avatar
Optimal? No. Entirely replacing all the sheathing would be optimal, and you can add enough thickness to it to get to the closet flange's height. In my opinion anything less is a band aid for a bleeding wound that needs medical attention.
The Following User Says Thank You to Termite For This Useful Post:
b_corwin (02-04-2011)
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 07:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
Where is the toilet vent?!?!? domgbrown Plumbing 4 01-11-2008 06:33 PM
