Subfloor Patch - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2011, 06:46 PM   #1
Subfloor patch
Hi all,
I patched a section of subfloor in my house. The subfloor material is the same but there appears to be some variations in thickness. As a result in some places the patch lies 1/16 to 1/8 of an inch below the adjacent subfloor.
I am planning to go over the entire area with another layer of 5/8" ply before putting down vinyl.
My question is what should I do, or do I need to, level out the joints. I figured I could shim it up, but that seems like the wrong thing to as I imagine I want the subfloor flush to the joists. The other option is that I could just take a belt sander and feather out the small lip?
Thoughts? Better ideas?
Thanks much
Brian
b_corwin is offline   Reply With Quote
Old 02-21-2011, 07:13 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
When you do that...drop a few gobs of construction adhesive in the low area. When it hardens and dries it will bridge the area and firm it up.
XXX
Old 02-21-2011, 07:35 PM   #3
Thanks Bud
Old 02-21-2011, 07:36 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You betcha!
XXX
Old 02-22-2011, 08:44 AM   #5
put some screws in the edge of the higher subfloor to see if it can be drawn down any more
mrgins is offline   Reply With Quote
