Subfloor Over Concrete Pad? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-10-2013, 09:43 PM   #1
Subfloor over concrete pad?
I am a DIY but have many years of experience building structures and additions in VA. Moved back to NY and want to finish an existing room that is roughed in (was a garage at one pt). The floor is a concrete slab, the walls are 2x4 16" OC. I have a few questions; (1) would it be smart to build a sub floor on top of the slab before finishing it and if so would 2x4 or 2x6 be enough? Can I insulate it? Should I put a poly weather barrier between the slab and sub floor? (2) should I insulate w/ R13 in the 2x4 walls or add 2x6's to get R20? Thanks so much for any and all advice.
JCrew
Jcrew is offline   Reply With Quote
Old 04-11-2013, 09:17 AM   #2
"You can do anything"-Mom
brockmiera's Avatar
How big is the room? Do you have a picture or a sketch? How far would the joists span?
brockmiera is offline   Reply With Quote
Old 04-11-2013, 10:30 AM   #3
GBrackins's Avatar
Rewards Points: 2,104
Welcome to the Forum JCrew!
a few questions:
is there a slope to the concrete slab?
what is the distance from existing dwelling finish floor to the slab?
what is the existing ceiling height in the garage?
is this in NY state or NYC? (different building codes)
is there a man-door? (hinged door)
one or two overhead garage doors?
is the wood wall framed above the concrete slab (does foundation extend above slab)?
depending on answers and how you'd like to approach there are several ways to address this.
is NY state you can get a jump with this link to the State Codes http://publicecodes.cyberregs.com/st...010-999999.htm
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 05:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
