Subfloor On Floor Joists. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2012, 05:15 PM   #1
subfloor on floor joists.
should i leave a gap between sheets of plywood when i screw them down/
djc300 is offline   Reply With Quote
Old 03-29-2012, 06:02 PM   #2
Framing Contractor
Rewards Points: 126
Yes, and also make sure that you use the tongue and groove plywood or osb.
sixeightten is offline   Reply With Quote
Old 03-29-2012, 06:04 PM   #3
Haverhill Trade 1965
If you are using tongue & groove it is usually stamped on it, how much space to leave on edges and at ends. If left exposed to weather long it swells, and most spaces disappear. The thing is that the sheets are 96 inches long. If you leave the required spacing at the ends your plywood is running long after 4 or 5 sheets. Sooooo, I space edges and keep ends tight.end grain swells and shrinks very little.
Duckweather is offline   Reply With Quote
Old 03-29-2012, 10:58 PM   #4
Registered User
Rewards Points: 526
What will be the final flooring?
T&G requires glue on the joists and in the groove. "(a) Edges of sub-floor panel must be supported by tongue and groove joints or solid blocking unless covered with underlayment, lightweight concrete, or wood strip flooring." http://www.apa-europe.org/Languages/.../PDF/R340G.pdf
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
woodworkbykirk (04-03-2012)
Old 03-30-2012, 04:37 AM   #5
Framing Contractor
Rewards Points: 126
That's what saws are for.
Old 04-03-2012, 11:03 AM   #6
thanks to all answers. i left about an 1/8 inch gap on the ends and glued the T and G to the joists.
Old 04-03-2012, 11:44 AM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,326
depending on the manufacturer of the sheathing they will sometimes make the tongue larger than the groove depth wise so to create the required gap for expansion. the ends should be tight so to ensure proper alignment of the panels if not its very easy for the sheets to become out of square which makes each succeeding row harder to lock together
woodworkbykirk is offline   Reply With Quote
Old 04-06-2012, 08:35 AM   #8
Rewards Points: 38
Hello guys, newbie here.
I understand the logic behind leaving gaps on the subfloor, but where do you leave the gaps if you are using toung and groove plywood? At the top and bottom?
lmholmes11 is offline   Reply With Quote
Old 04-06-2012, 11:08 AM   #9
Rewards Points: 14,278
T & G plywood has built in spacing. You will notice as it's being tapped together it's going to stop before it's tight.
