Subfloor First Or Framing First - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-08-2013, 02:44 PM   #1
Rewards Points: 236
Subfloor first or framing first
I have been looking for the answer to this question as I am in the process of finishing the basement.
Should I install subfloor first or framing first?
325_man is offline   Reply With Quote
Old 03-08-2013, 03:19 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 346
Subfloor, in a basement?
Are you doing some kind of special system? Tell us more.
Jaz
Old 03-08-2013, 03:39 PM   #3
Rewards Points: 196
Only reason I can think of for a subfloor is if you are doing a raised floor. Maybe heated floors, very uneven slab or some other reason. Usually you dont need to install a sub floor in a basement
Jason34 is offline   Reply With Quote
Old 03-08-2013, 04:50 PM   #4
Rewards Points: 236
Jaz
Nothing special planned for the basement floor. I just want to finish the basement, to add more living space.
I was thinking to have tile flooring.
Old 03-08-2013, 04:53 PM   #5
Rewards Points: 13,458
If the slab is flat then there's no need for a "subfloor".
I would build the walls first then lay the floor.
Old 03-08-2013, 05:01 PM   #6
Rewards Points: 512
if you are tiling then there is no need for a subfloor. People put subfloors in because they may have a minor leak or water problem and their flooring and contents don't get destroyed. also you dont feel the damp cold floor. i would doing your framing first then your subfloor. Do not put your framing on your subfloor. If you ever had a water problem bad enough to pull up the floor just imagine trying to tear it out with the walls on top of it.
princelake is offline   Reply With Quote
Old 03-08-2013, 05:18 PM   #7
Roofmaster
Rewards Points: 2,172
Normally, you lay out your walls on the concrete slab with a chalk line, then anchor a pressure treated sole plate to the concrete floor. 1/4 inch Rawl spikes are good for this. You need a decent hammer drill. I have a Hilti TE-12S that I love. You then build your walls on the floor with a plate on top and bottom. Stand them up Plumb and shim, then screw to joists or blocking placed between joists. Electric and plumbing, insulation, drywall finished and painted. then floor, then trim. Ive seen the drycore stuff, and I don't buy it. If you have a wet basement you have to fix it outside, not inside.
Old 03-08-2013, 08:55 PM   #8
Tileguy
JazMan's Avatar
Rewards Points: 346
It's not a matter of if the floor is flat or just thinking it's a good idea to build a subfloor on a slab which is below grade. Someone show me the spec that says building a sleeper-floor below grade is recommended anywhere.
It can work under some situations, but wood in contact with a slab below grade is not a good idea. Plus trapping moisture from a slab can be a problem and often is.
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
oh'mike (03-09-2013)
Old 03-09-2013, 10:12 AM   #9
Rewards Points: 236
Got it! Framing first, then subfloor next.
Thanks all!
Old 03-09-2013, 10:26 AM   #10
Tileguy
JazMan's Avatar
Rewards Points: 346
Oh boy!.........
Jaz
Old 03-09-2013, 11:46 AM   #11
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,116
if your using a floationg interlock sub floor system you have to frame the walls first. if you build the walls on top of it the subfloor will buckle
woodworkbykirk is offline   Reply With Quote
Old 03-09-2013, 02:57 PM   #12
Professional Wood Shafter
ryanh's Avatar
Rewards Points: 154
Always add subfloor after walls. Basement walls should be floated from the floor so keep the subfloor away from under walls so it can move if need too
ryanh is offline   Reply With Quote
Old 03-09-2013, 03:39 PM   #13
DIY staff
Rewards Points: 7,174
Thanks all!
Framing only--NO subfloor at all---you have a floor all ready to accept tile---you do not need or want anything more.
drtbk4ever (03-20-2013)
Old 03-19-2013, 10:14 PM   #14
I have done this before a few times build the walls, then put sleepers if you wish. personally I would ardex the slab and lay tile
ubcguy89 is offline   Reply With Quote
Old 03-20-2013, 11:56 AM   #15
Rewards Points: 31
Jaz
What if you use a 1" rigid foam and t&g ply on top for better insulation and a warmer floor?
ccleme11 is offline   Reply With Quote
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 03:17 PM
Framing question, basement/first floor remodel enoll Remodeling 0 02-22-2012 12:01 PM
Any opinions on panelized framing? TitaniumVT Building & Construction 5 12-29-2009 01:56 PM
Framing for drywall under Spiral staircase clemon03 Drywall & Plaster 6 07-17-2009 03:49 PM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
