Subfloor Expansion And Contraction - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-25-2011, 09:45 AM   #1
Rewards Points: 121
Subfloor Expansion and Contraction
It seems to be standard practice to leave about a 1/8" or so gap between subfloor panels to allow for expansion and contraction. Is this true when you use a subfloor adhesive? The reason I ask is that I just read an article that states you should not use an adhesive on wall and roof sheathing because it prevents necessary expansion and contraction and may lead to the buckling of the panels. I realize that a floor system may not be subject to the same moisture issues of walls and roofs. But it just seems the subfloor adhesive would make the gap unnecessary since it will prevent almost all expansion and contraction. (This is just a question mostly out of curisoty since it is no effort just to put in the gaps and not worry about it)
jrepp44 is offline   Reply With Quote
bamboo flooring contraction shirleypearl Off Topic 0 05-24-2010 10:01 PM
ABS Thermal Contraction steven723 Plumbing 6 01-24-2009 07:38 AM
Concrete Q: expansion and contraction after 30 years Deck Building & Construction 9 05-23-2008 11:21 AM
