Subfloor On Concrete. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-31-2012, 07:52 AM   #1
Subfloor on concrete.
I have a carport and a bonus room/workshop that is attached to my home by the roof but not any of the exterior walls. I am going to be attaching the workshop and building out the carport so that it is part of the house. I am on a slab foundation in the Indianapolis area.
My problem is the flooring in the carport. There is a 3" rise from the carport to the house. I have thought of using a DriCore type system but that would still leave me roughly 2" difference in height. Any ideas on how to finish the floor so it is flush with the house? Thanks
Handy DIY is offline   Reply With Quote
Old 01-31-2012, 08:11 AM   #2
Rewards Points: 13,960
Some pictures would sure be nice.
You can install what's called sleepers. It's framed in floor joist out of pressure treated wood set over a vaper barrier.
More the likly that old slab will have a taper to it and be unlevel so this has to be shimed to account for that.
RenoStruct (01-31-2012)
Old 01-31-2012, 11:02 AM   #3
Registered User
Rewards Points: 526
I would check to see if a permit is required for this future conversion. Most carports have just a 3-4" concrete slab, with no footings under the outside edges to support a load-bearing wall. It may be easier to pour a new slab with a thickened perimeter and a plastic vapor barrier under it to stop the rising damp. Carport roofs are not designed as house roofs, you will probably need to make a few changes there, also (insulation, ventilation, structural). Then there is wiring, heat and ventilation, egress, etc. Be sure to leave the "paper trail" for your H.O. Insurance carrier in case of future claims and if you ever decide to sell. (So that you won't be required to rip it all out and can list it as "living space".
Gary
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Need concrete tips and suggestions spaceman spif Building & Construction 4 10-05-2011 09:08 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
