Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-06-2009, 10:49 AM   #1
Subfloor
I am getting ready to put down a subfloor in my attic and I have ran into a problem. There is a group of wires running across the middle 1/3 of two joists. I know its agaisnt code to notch in this area and was wondering if anybody had any suggestions. There are probably 8 wires including the 220 for the heat exchange. The joists are 2x12s, 16" OC, 20' span. Any help is appreciated.
KL1975 is offline   Reply With Quote
Old 03-06-2009, 11:01 AM   #2
Registered User
Termite's Avatar
Subfloor
We'll go on the assumption that the ceiling joists that make up the attic floor are spanned adequately for use as a floor system....
You could install 1x2 or 2x2 furring strips on the top of the joists to raise the floor level up a little. Just use some metal plates to protect your wires!
Old 03-06-2009, 02:16 PM   #3
Remodeling Contractor
Subfloor
If you cannot use the strips idea then but a junction box at each end and drill through the joists to reconnect. This is a much harder task then adding the strips. Which will also stabilize the floor a little.
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 07:29 AM
Subfloor Help, Please! OmahaGirl Flooring 1 01-26-2009 09:06 AM
Replaced section of subfloor but it's 1/16" higher. Is that a prob? Piedmont Carpentry 1 08-29-2008 11:12 AM
Subfloor / underlayment question... scheenstra Flooring 7 02-21-2008 08:39 AM
