Subfloor - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-01-2007, 06:14 AM   #1
Subfloor
This question is something you'd learn back in Grade 1 but amazingly I don't know the answer!!
I'm building a 8 by 8 subfloor with 2x4 pressure treated lumber in my basement bathroom. Now here's the brain teaser...crown up or down?
flyultralite is offline   Reply With Quote
Old 12-01-2007, 02:27 PM   #2
Rewards Points: 5,336
It's crown up and you don't use pressure treated wood.
Ron
Old 12-01-2007, 03:07 PM   #3
Home Improvement Guy
ron schenker's Avatar
The other Ron is right
Crown down would have hollow spots in the subfloor which would create havoc with your new flooring
ron schenker is offline   Reply With Quote
Old 12-02-2007, 12:18 PM   #4
Rewards Points: 26
He is building a subfloor to be placed on the basement concrete is how i read it. I WOULD use pressure treated 2x4s for this since the wood is going to be in contact with concrete which has moisture in it. Whenever you frame a wall in the basement the bottom plate is always treated wood.
ponch37300 is offline   Reply With Quote
Old 12-03-2007, 07:05 AM   #5
Thats what I thought too. I built it with PT, better safe then sorry. Thanks for the help guys!! You'll hear from me with another question soon...real soon.
Old 12-06-2007, 04:34 PM   #6
Insulation??
Hi, its me again...there's no harm with insulating the subfloor is there? The way I see it, is the subfloor is basically a wall on he ground. I ask this cause it's something I've never read about on this site nor in my DIY HomeBook.
Old 12-06-2007, 05:39 PM   #7
Rigid foam would be good
Old 12-06-2007, 06:16 PM   #8
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Crown: Sideways...
- Build Well -
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 08:37 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 09:06 AM
subfloor for laminate and tiles mf915 Flooring 10 05-18-2006 04:01 PM
COMPLETE subfloor removal alexschmidt Flooring 4 08-02-2005 11:15 PM
