Sub Pump Drainage Problem - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 06:35 PM   #1
WindowTreatment Installer
Sub pump drainage problem
Our house is 12 years old. My sub pump discharges into a drain pipe that goes under ground and leads to the sewage toward the street. Problem is the builders use flexible piping and when the ground settled, so did the pipe. So the water doesn't get past where it settled and therefore backs up and and over flows right where the pump discharges. This causes the pump to work even harder. It's about 50 ft to the street. Had a plumber take a look and wanted $2500.00 to dig it up and lay new pipe. Is this reasonable or is there another to go about fixing this.
bobtheblindguy is offline   Reply With Quote
Outside drainage problem drjay9051 Plumbing 4 08-08-2010 11:49 AM
Problem with drainage in two new vessel sinks jpmain Plumbing 7 06-11-2010 12:17 PM
Drainage problem, basement flooding thunderhead Plumbing 1 06-05-2010 08:05 AM
Drainage problem in backyard - Planting Cedar will help? riniboo Landscaping & Lawn Care 2 04-11-2010 10:23 PM
Drainage problem, water under the house Rockobuster Landscaping & Lawn Care 2 01-04-2010 03:52 PM
