To Sub Out Or Not To Sub Out- Concrete - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-28-2013, 12:03 AM   #1
To sub out or not to sub out- concrete
I have a 40'x15.5' metal building I'm converting into a man cave. The concrete floor is a problem though. The rear 25' is stepped and sloped to allow it to be rinsed clean. The center 5' is makes a 2" elevated walkway. At the walls the floor is level with the walkway. They then slope down 2" to a conduit running the length of the building. Then you step up 2" to the center walkway. I've calculated 4 yards of concrete will be needed to level the floor and overlay the center walkway 1".
I have NEVER worked with concrete. I'm pretty darn handy though.
My questions are:
1) will a 1" overlay be thick enough at the center of the room to support the weight of a pool table and wet bar without cracking?
2) is it better (better product, stronger, easier, etc) to rent a mixer and mix the concrete on site or have it delivered?
3) I'm a retired cop on a very fixed budget. I've gotten a bid of $900 to do everything, mixing on site. Would it be cheaper to try to tackle this myself, and what would that entail?
4) once the concrete overlay is down, does it matter what concrete I use as far as staining is concerned? We like the marbled look seen everywhere online.
5) what am I missing or overlooking? What pitfalls do I need to be aware of whether I do it or have the company do it?
Thanks all. I just can't afford to get this wrong and waste money fixing it, but I don't have an extra $300-$400 to throw away if I can save it and do it myself with some sweat and sore muscles.
Tattooedmick is offline   Reply With Quote
Old 02-28-2013, 07:05 AM   #2
Rewards Points: 150
First off I would get a couple bids especially ftom big reputable companies if only to find out if what u ask I'd the right way to go
kaschmid3 is offline   Reply With Quote
Old 02-28-2013, 08:29 AM   #3
Thanks for the feedback.
That was the median quote out of 4. I got everywhere from $1600 to $700.
Old 02-28-2013, 09:02 AM   #4
Rewards Points: 150
U can also ask if price is different if u do all the moving if concrete and they do the finesse smoothing and attaching if needed
Old 02-28-2013, 10:32 AM   #5
Rewards Points: 3,722
My questions are:
If you have never worked with concrete,then you really don't want to start with this project,especially with staining involved,also ask the person who is bidding the job if it's possible to see examples of their work,before you sign on the dotted line.
Canarywood1 is offline   Reply With Quote
Old 02-28-2013, 10:50 AM   #6
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
I poured a strip of concrete at a major airplane manufacturer that was only about 1-2" thick. Apparently some engineer thought you could run a 787 over it and not have it crack. I didn't think so, and the finishers didn't think so, but someone with a college degree did. I imagine your pool table won't be much of a problem.
It's almost always easier to have it delivered, and the mix will be more consistent, and the strength will be guaranteed as long as you don't add too much water. Depends on how much you need (and its too early in the morning for me to do math), but if its over a yard or two, don't bother mixing it yourself.
It'd certainly be cheaper, because you're only paying for materials, not labor. But again, if you have it done by a reputable contractor, you have that guarantee that it will be exactly what you want.
Whenever we use stamp mixes, it's always a pea-gravel mix (no 1"- rocks), but if you aren't stamping and just staining, it shouldn't matter.
Do you have any friends that have done concrete work? If so, beer and pizza may buy you some valuable knowledge. Concrete is different for the DIYer, because it is unforgiving. If you're framing a wall or wiring an outlet, if you get stuck, you can take a picture, surf around online for help, take a step back for a day or two, and nothing will go wrong. When placing concrete, you have 45 minutes to an hour, and that's it, Jack. And its a lot of work to remove a bad concrete pour.
I hope this helps a little.
Mort is online now   Reply With Quote
The Following User Says Thank You to Mort For This Useful Post:
concretemasonry (02-28-2013)
Old 02-28-2013, 11:19 AM   #7
GBrackins's Avatar
Rewards Points: 2,108
I agree with Mort's comments. I was taught however in college and in practice never to place less than 2-inches of concrete (but I went to college 40 years ago) but maybe things have changed. I've never specified less than 2-inches and never had any issues.
I'm very handy having grown up in the construction business, but I find now that I'm older its' cheaper to hire stuff like this out than to tackle it myself as my insurance does not cover my chiropractor ...... LOL
Good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 03-01-2013, 09:19 AM   #8
Thanks All,
I calculated 4.5 yards on concrete. That's a whooooole lot of bags! So I'm pretty resolved I'm going to have to have it trucked in. Concrete is running $89 a yard with a $250 delivery fee. If I try to find day laborers with concrete experience on Craigslist or something, I think I'll have to at least pay them $100 each x2 workers. Seems like $900 to have it done just makes more sense.
Kinda hurts though. Thats $900 that can't go into stocking the bar!!!
Thanks everyone for your feedback. I'm sure I'll have more questions as the work commences, so I appreciate your patience with me.
The Following User Says Thank You to Tattooedmick For This Useful Post:
jomama45 (03-01-2013)
Old 03-03-2013, 11:02 AM   #9
Mort's Avatar
Rewards Points: 692
That's why we're here man. Materials and labor for $900 on a 4.5 yard project sounds like a steal to me. I'm a DIY freak, only ever hired one contractor in my life (duct cleaner, I'm very allergic to dust), and I'd even hire this one out.
Post some before/during/after pics. I always like some good man cave ideas.
I hate signatures.
Old 03-03-2013, 11:24 AM   #10
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,248
if your pouring a slab dont even attempt a diy at it.. ive placed a large amount of concrete and i work in renovations. we pour the concrete for the icf walls we build but we have someone else do our slabs..
woodworkbykirk is offline   Reply With Quote
Old 03-03-2013, 11:54 PM   #11
I appreciate everyone's responses. Truly. I'll post up some pictures as the project goes along. I'm quite sure you'll be seeing me pop up a lot over the next few months!!
Gap in concrete by corner of garage door jamb, intentional or not? daluu Concrete, Stone & Masonry 1 09-16-2012 05:23 PM
How to Calculate Store Bought Concrete Coverage by Bag Size Willie T How To Guides 9 11-29-2011 12:32 PM
Laminate Flooring on Two Different Concrete Heights mrken Flooring 4 12-14-2010 01:56 PM
New Concrete Walkway along side of house braverichard Building & Construction 0 11-03-2010 11:12 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 09:49 AM
