Old 03-04-2011, 07:54 PM   #1
Sub Floor Warped- Raised House under construction
Before the roof had been felted we experienced heavy rain for a number of days. The first sub floor of my raised house has warped badly. The first floor is about 2000 sq. feet. We were planning on installing real wood floors which need to be nailed down to the subfloor. What can be done to correct the warped subfloor?
The headers and exterior doors are already in place. The contractor is looking into using patch over the low areas and then coming back with 1/2 inch plywood,but he is not sure that we will be able to do that because of the door headers and doors that have been ordered.
In time will the plywood dry out and become un warped?
Could the plywood subfloor be sanded down so that it's level?
Can all of the plywood subfloor that will have wood floors be replaced?
Help
First time Home builder
bjlebel is offline   Reply With Quote
Old 03-04-2011, 08:19 PM   #2
They will dry out, but they will not,"unwarp". Whether you can fix the floors depends on the extent of the damage. A small amount of warpage can be sanded out.
I have no idea what, " using patch over the low areas and then coming back with 1/2 inch plywood" means, but it sounds like a half-assed solution from someone who wants to limit his liability.
Take some pictures.
Ron
Old 03-05-2011, 07:43 AM   #3
Framing Contractor
This guy can't be a contractor to say that. He has no idea what he's talking about.
No.! The simple solution is that he replaces it. This is something that is done every day. It takes time but that's the only way to fix it.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 03-05-2011, 07:58 AM   #4
what thickness subfloor are we talking, when i was framing 3/4 and it would take alot of water and still be stable. To bad no drain holes were drilled
The older I get the better I was
Installing a Dishwasher in a raised house from scratch cpshockl Plumbing 4 05-19-2010 06:43 PM
Paver patio for raised foundation house? sandyman720 Landscaping & Lawn Care 1 05-06-2010 06:06 PM
Foam Board on exterior of above grade house Sheldon General Discussion 6 12-08-2009 05:05 PM
Raised center beam in house Stude Building & Construction 5 12-08-2009 04:01 PM
