Sub Floor Dry Rot Under Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 06:59 PM   #1
User
Sub floor Dry rot under wall
Bathroom had extensive dry rot but most of it easy to get to.
Except where the T&G goes under the non load bearing wall into the bedroom.
Floor is 1 1/8" with 3/8 particle board underlay.
I plan on replacing "in place" the bottom plate that is almost gone and the wall studs that are damaged. Non load bearing wall.
I want to take out as much of the damaged wood that I can access and plan on sliding it under the wall when I remove the bottom plates. The wall will be temporarily supported.
Any thoughts on this or easier way?
Subcooled is offline   Reply With Quote
Old 02-13-2011, 07:42 PM   #2
DIY'er
jamiedolan's Avatar
Rewards Points: 1,024
It's not a problem:
Notice missing studs against brick wall.
Jamie Dolan - Neenah, WI
Jamie Dolan Paw Dogs
Need Help Uploading Photos? Click here.
jamiedolan is offline   Reply With Quote
Old 02-13-2011, 11:07 PM   #3
User
Sometimes nice to see others with the same issue, not that it's good but....
Old 02-13-2011, 11:11 PM   #4
DIY'er
jamiedolan's Avatar
Tore out my whole kitchen due to that water damage. Still working on getting the kitchen rebuilt over 2 years later :-(
Replacing load bearing wall KarlJay Building & Construction 4 12-27-2013 03:44 PM
Is this wall bearing? adamgram Building & Construction 15 01-18-2011 09:32 PM
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 12:30 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Load Bearing Wall? Traybae Building & Construction 1 11-05-2006 01:01 PM
