-   -   Sub floor Dry rot under wall (http://www.diychatroom.com/f19/sub-floor-dry-rot-under-wall-95411/)
Subcooled 02-13-2011 06:59 PM
1 Attachment(s)
Bathroom had extensive dry rot but most of it easy to get to.
Except where the T&G goes under the non load bearing wall into the bedroom.
Floor is 1 1/8" with 3/8 particle board underlay.
I plan on replacing "in place" the bottom plate that is almost gone and the wall studs that are damaged. Non load bearing wall.
I want to take out as much of the damaged wood that I can access and plan on sliding it under the wall when I remove the bottom plates. The wall will be temporarily supported.
Any thoughts on this or easier way?
jamiedolan 02-13-2011 07:42 PM
It's not a problem:
http://www.dolanhosting.net/jamiedol...n/IMG_3392.JPG
Notice missing studs against brick wall.
Subcooled 02-13-2011 11:07 PM
Sometimes nice to see others with the same issue, not that it's good but....:eek:
jamiedolan 02-13-2011 11:11 PM
Tore out my whole kitchen due to that water damage. Still working on getting the kitchen rebuilt over 2 years later :-(
