Old 08-04-2012, 10:48 PM   #1
Sub floor
Hello all,
I am looking for some help with some building questions.
I am currently finishing my basement and need help covering a 1 1/2 PVC pipe for the sump pump. I am covering the entire floor with delta fl flooring membrane and am not sure how to build up the floor on top of that to clear the pipe. The room is approximately 10x10.
miconob is offline   Reply With Quote
Old 08-05-2012, 07:36 AM   #2
Sub floor
2x4's laid flat(tapcons or similar), with plywood in top, then finished floor. Insulate between the 2x4's with rigid XPS foam.
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 10:12 AM
Dryer duct hole thru band joist & floor joist justplumducky General Discussion 12 10-05-2010 01:31 PM
Split level walls and floor joists - how are they constructed? jrbutterfly Building & Construction 2 06-09-2009 01:11 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 05:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 08:45 AM
