Sub floor
Hello all,
I am looking for some help with some building questions. I am currently finishing my basement and need help covering a 1 1/2 PVC pipe for the sump pump. I am covering the entire floor with delta fl flooring membrane and am not sure how to build up the floor on top of that to clear the pipe. The room is approximately 10x10. Thanks |
2x4's laid flat(tapcons or similar), with plywood in top, then finished floor. Insulate between the 2x4's with rigid XPS foam.
| All times are GMT -4. The time now is 11:05 PM. |
