Old 03-23-2010, 09:48 AM   #1
styrofoam insulation installation
I am going to put 2 inch styrofoam insulation on my 30 yr. old 4-level split house after I remove the old siding. Then add new vinyl siding later.
Does putting 2x2 furring on first and butting the sheets of insulstion to them cause any problems with lowering the insulation factor or is the correct way to do it?
Is there anything I should be careful with or watch for?
I am installing styrofoam insullation to the exterior of a 30 year old house and want to know if it is advisable to add furring. And will it reduce the insullation integrety of the home.
I would like some advice on what to be careful of when I do this job.
(2 threads on same subject merged)
-Moderator
iampots is offline   Reply With Quote
Old 03-25-2010, 08:54 PM   #2
gravity always wins
What type of construction are the walls of the house made up of?
Framed? Block?
Maintenance 6 is online now   Reply With Quote
Old 03-26-2010, 06:48 AM   #3
Hi
It is 2X4 lumber on 16 in. center.
Old 03-26-2010, 10:16 PM   #4
Moderator
What kind of siding will you be removing?
Be safe, Gary
Clothes taking longer to dry?
Old 03-28-2010, 12:10 PM   #5
The old siding is X90.
Old 03-28-2010, 05:14 PM   #6
Tom Struble's Avatar
do you have enough roof overhang for the desired thickness of siding and foam?2'' is a pretty thick expensive foam board,do you understand the flashing details that are needed to sucessuly keep bulk moisure from the structure?
installing furring strips and insulating inbetween is not the best idea
Tom Struble is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
Insulation Installation Question avtck Remodeling 0 01-21-2010 03:11 PM
What kind of adhesive to use on Styrofoam insulation? tripower Building & Construction 9 05-19-2009 09:39 AM
Attic Insulation Installation oktooma Building & Construction 3 10-29-2008 04:46 AM
