Styrofoam Insulation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-29-2008, 01:27 PM   #1
Rewards Points: 163
Styrofoam insulation
I wonder if it would be a good idea to use styrofoam insulation for the roof and walls instead of fiberglass. Could anybody shed light on it?
Thanks.
dpreznik is offline   Reply With Quote
Old 07-29-2008, 02:04 PM   #2
Registered User
Termite's Avatar
Spray-on expanding foam insulation is very effective. The most common brand that I know of is Icynene. Plan on spending big bucks for it up front, but it is much better than conventional batt or blown insulation, so eventually you'll offset the savings in energy costs. It is not a DIY product.
EPS foamboard is not a good product for use in walls or attics. It can't be left exposed in the attic, and is best used where intended...Below grade or as an insulative sheathing material.
Old 07-29-2008, 03:56 PM   #3
worm can opener
FYI Icynene has zero off-gas after it's cured.
Wahoo is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 08:20 AM
Better Insulation for 2x4 Walls? whiskeykid Carpentry 7 07-08-2008 04:51 PM
Insulation over Attic Walkway BigJimmy Building & Construction 4 06-23-2008 02:13 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 05:21 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 08:33 PM
