Old 07-06-2007, 11:39 AM   #1
Sturdying a wood fence
I have begun to erect my 4 ft wood fence. After getting few panels complete, I noticed that when I shake the panel, it vibrates. I know there will always be some shake in the fence but I was wondering what I could do to make it more sturdy. I was thinking of driving a steel stake in the middle of each panel and then connecting that to the fence at the bottom. Any other experiene with this?
cibula11 is offline   Reply With Quote
Old 07-06-2007, 01:29 PM   #2
Do you have 2x4 horizontial mebers that hold up the pickets?
redline is offline   Reply With Quote
Old 07-06-2007, 02:41 PM   #3
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
I have used those metal stakes that are used for wire fencing to support old wobbly posts as a temporary fix. If this is a new fence it should not wobble. How are you installing the posts?
Brik is offline   Reply With Quote
Old 07-06-2007, 09:40 PM   #4
The posts don't move, but the panel does.
I have used 1x4 rails to attach my pickets. 2x4 would have been too large.
Old 07-06-2007, 11:18 PM   #5
Both sides of the fence will look identical. So I am basically placing my pickets sandwiched between two 1x4's on the top and bottom and then centering them on a 4x4 post. As a finish, I will be placing a 1x4 flat on top of each section and finishing with post caps. I am hoping that when placing the 1x4 flat, I will gain some strenght. It is only 4 ft so I am hoping a little movement will be okay??
wood fence post farrington135 Building & Construction 11 05-17-2011 03:32 PM
Wood Fence Post through Driveway shofnerd Landscaping & Lawn Care 10 02-21-2011 12:20 AM
Preferred Fence Wood? Medium_Pimpin' Building & Construction 2 07-06-2007 10:21 AM
How to pre-treat wood for fence? nebben Landscaping & Lawn Care 3 04-29-2007 10:14 AM
privacy fence wood question mr_man Building & Construction 2 04-10-2007 11:09 PM
