Stupid Masonry Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2008, 01:54 PM   #1
Rewards Points: 1,062
Question
stupid masonry question
okay, since i've never really erected anything in masonry (only done pouring concrete slabs), i decided my backyard shed/storage (not quite a garage) will be 100% cinder bloc with poured concrete slab as a flat roof that will also be a terrace on top (will have poured concrete or metal stairs on the side).
question: once i have done laying walls in cinder blocks, how do i set a frame into which to pour the roof slab on top ? this is also more of a european construction style (as wood is more expensive there than concrete).
thx,
- a -
Old 02-21-2008, 04:39 PM   #2
Wood would be cheaper.
redline is offline   Reply With Quote
Old 02-22-2008, 03:13 AM   #3
Rewards Points: 26
So you want to build a frame to hold up a cement deck and people on top? For the cement to support it's own weight and the weight on top of it there is alot that needs to be done and will cost alot more than wood. You would need alot of support underneith of the concrete and kinda defeat the "shed" under the terrace.
ponch37300 is offline   Reply With Quote
Old 02-22-2008, 05:34 AM   #4
General Contractor
joasis's Avatar
A concrete deck or roof on a cinder block structure? Are you filling the blocks? Do you have any engineering information on spans of concrete, and the vertical load you can place on CMU blocks? Any building codes in your area?
Ladwig Construction
Hennessey, Oklahoma
405 853 1563
joasis is offline   Reply With Quote
Old 02-22-2008, 06:50 AM   #5
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
I was thinking the same thing.
To design, fabricate, install, etc.... a structurally sound, and code approved concrete roof arrangement is not a DIY type project.
Re-consider a much simpler and cost effective design - with wood.
- Build Well -
Old 02-22-2008, 08:21 AM   #6
will consider wood
thanks !
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
stupid framing question amakarevic Building & Construction 12 02-23-2008 03:29 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
Embarrassingly stupid question about latex paint joeyboy Painting 7 08-20-2007 09:25 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 09:48 PM
