Stumped On Foundation Type? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-30-2015, 04:44 PM   #1
Rewards Points: 54
Stumped on foundation type?
Hey guys it's been a while since I've posted on here, but I have a question. My family has outgrown our current house and we looking to buy an older home. My wife and I found a Colonial style home we like (build date not known) but I'm a little confused about the foundation. The houses in my area (Central Texas) usually have either pier and beam or slab foundations. This particular home has a sunken like crawl space. There are two areas to enter the crawl space on the exterior of the house. When you crawl through opening it drops like 2 ft. (duct work for A/C was also ran under the crawl space for 1st story) Could someone please help me identify this type of foundation? Are there any concerns to having this type of foundation? I can possibly take better pics tomorrow. Thanks
Stumped on foundation type?-img_5697.jpg   Stumped on foundation type?-img_5718.jpg
will04 is offline   Reply With Quote
Old 08-30-2015, 04:51 PM   #2
DIY staff
Rewards Points: 7,174
A few more details----is it a concrete,poured foundation--similar to a full basement but shorter?
Is it made of concrete block and faced with brick?
Is it all brick?
Are the floor joists resting on the foundation?
The picture has me wondering if it is a true foundation or a brick skirt around a post and beam structure.
mae-ling (08-30-2015)
Old 08-30-2015, 05:10 PM   #3
Rewards Points: 1,644
That house could possibly be pre civil war.
Old 08-30-2015, 05:16 PM   #4
Rewards Points: 54
Is it all brick?
I'm suppose to possibly go look at it tomorrow a little closer. I'll take better pics of foundation. I'm not sure about the brick. I'll have to do a little more investigating. But I'll post more pics as soon as I can. I do know the house will need leveling.
The Following User Says Thank You to will04 For This Useful Post:
oh'mike (08-30-2015)
Old 08-30-2015, 05:33 PM   #5
Rewards Points: 948
Based on the one photo it looks like pier and beam. The brick was probably added later. (The beam running behind the post is a bit curious, need to see what is carrying what, then it will be clear.)
keymaster is offline   Reply With Quote
The Following User Says Thank You to keymaster For This Useful Post:
Old 08-30-2015, 05:59 PM   #6
Rewards Points: 54
I'll go take some pics now. Post when I get back
Old 08-30-2015, 07:23 PM   #7
Rewards Points: 54
Here are the pictures of the foundation. The brick was added later for looks I guess. The A/C duct work would need to be lifted off of ground.
Stumped on foundation type?-img_5723.jpg   Stumped on foundation type?-img_5722.jpg   Stumped on foundation type?-img_5724.jpg   Stumped on foundation type?-img_5721.jpg
Old 08-30-2015, 08:27 PM   #8
DIY staff
It looks like a standard concrete foundation(likely sitting on a footing) with a brick face.
To bad the did not dig the crawl space deeper----
If you get close to putting in an offer--I suggest you hire a foundation specialist to look at that and give you an assessment.
We have several members that know their foundation work--wait for more replies---
Standry would be good to hear from.
will04 (08-30-2015)
Old 08-31-2015, 11:57 AM   #9
Rewards Points: 948
Seeing the other photos, it's obviously not a posted foundation. Beyond the foundation, be diligent in your inspection of the entire house. There are some areas of concern, like siding that shows possible discoloration near the windows (moisture), the bay window roof and siding, the chimney. The roof looks pretty good.
Old 08-31-2015, 12:41 PM   #10
Rewards Points: 54
Thanks, the bay windows may have been added later, not sure. My plans were to remove them, making the front flat and add windows in there place That way it would look like a traditional Colonial. I also noticed the discoloration on the siding. How do you think the water (moisture) is working it's way behind the siding? I've noticed the discoloration on the siding around several windows on the front of the house.
Old 08-31-2015, 02:06 PM   #11
Rewards Points: 948
I can't be certain, but likely suspects are improper head flashing and/or flashing at the gutter/cornice. The fact that it appears isolated to the second floor makes me think it's a roof drainage issue, but being parallel to the casing means it could be capillary. (It could be both.)
Old 08-31-2015, 10:53 PM   #12
Is it just me.???
Right side of house.
Second floor to the left of chimney.
Two windows, the one closest to the corner.
Bottom pane, anyone see a face.???
ron45 is offline   Reply With Quote
Old 08-31-2015, 11:09 PM   #13
Rewards Points: 54
Originally Posted by ron45 View Post
Is it just me.???
Yes I absolutely see it, That's crazy! Don't need to show wife until after we possibly purchase it!
Thinking about building any type of foundation? Deck? shed? lewisthepilgrim Building & Construction 1 11-14-2012 03:49 PM
1920's House Foundation Parging/Skim coat jut Building & Construction 4 08-28-2012 09:13 PM
What type of foundation for a 12x10' outbuilding dwoloz Building & Construction 1 10-02-2010 05:00 PM
Water coming in at base of foundation Ptron Building & Construction 22 08-09-2010 09:51 PM
frost protected shallow foundation retrofit for 100+ year old limestone foundation degnem Building & Construction 7 06-24-2010 06:33 PM
