Old 10-11-2012, 11:31 AM   #1
"You can do anything"-Mom
brockmiera's Avatar
Smile
Studs vs Furring Strips In the Basement
I am on the demolition phase of my basement remodel. The basement walls right now have 1x2 furring strips vertically every 16" O.C. attached directly to the basement walls. I want to put in extruded poly probably 1" on all exterior basement walls for a good thermal break.
My question is this. Should I frame a 2x4 stud wall just to the inside of the poly or should I use new furring strips vertically to attach drywall to?
My initial thought is to go with 2x4 wall but in the interest of saving valuable square footage a furring strip application will make the wall assembly much less intrusive.
Thanks in advance for your thoughts.
brockmiera is offline   Reply With Quote
Old 10-11-2012, 11:38 AM   #2
DIY Enthusiast
sublime2's Avatar
Frame it.
The space lose is minimal.
I would not rely on furring strips nailed to brick/ concrete to support the rock.
sublime2 is offline   Reply With Quote
Old 10-11-2012, 11:44 AM   #3
brockmiera's Avatar
yeah I was leaning that way anyway.
Another question. The bathroom before has tile glued directly to the wall with some sort of superman adhesive. Once I get all of that old tile off is it acceptable to put tile back on the walls?
My original thought was to use a shower membrane like Kurdi liner on the wall then tile to that. Or should I put up the rigid board insulation - shower membrane - then tile?
I really want to do this right but framing a new wall against the exterior wall will require me to move a lot of plumbing. I have a picture too if that will help.
Old 10-11-2012, 11:55 AM   #4
brockmiera's Avatar
Here is a picture of the wall in question.
Old 10-11-2012, 12:27 PM   #5
Newbie Bill
You are referring to the tiled wall with the window? I assume it is an outside wall given the insulation and window and that is part of the shower. Is that correct?
Is it a 2X4 wall now?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 10-11-2012, 12:30 PM   #6
brockmiera's Avatar
Yes sir. Outside wall - no framing now. Just tile thinset to concrete wall. that window will be in the shower.
Old 10-11-2012, 03:45 PM   #7
journeyman carpenter
woodworkbykirk's Avatar
framing fixes a few issues.
1) you get better insulation in the wall
2) easier to run electrical and plumbing
3) create a straight wall as opposed to furring strips applied to the foundation... telegraphs the irregularities in the wall.
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
sublime2 (10-11-2012)
Old 10-11-2012, 06:03 PM   #8
Newbie Bill
Ouch, that isn't ideal. Could you frame any kind of wall there without impacting your plumbing?
Bill
Old 10-11-2012, 06:39 PM   #9
brockmiera's Avatar
Yeah I suppose I could go with a 1/2" Extruded Polystyrene board / 2x2 framing (or furring strips glued to the Poly board)
I'm curious to find out if anyone thinks using the 1/2" Poly Board with either a concrete board / membrane set up or just membrane would work???
Old 10-12-2012, 11:11 AM   #10
brockmiera's Avatar
So after much research I've decided to go with a 1/2" Kerdi Board product. The is a polystyrene board with the kerdi membrane already applied to it. Seems like the best of both worlds. Thanks for the feedback. I'll start posting my progress on another feed.
Tags
basement, framing, furring strips, insulation, remodel
Furring Strips For Radiant Barrier cdonahue Roofing 2 09-10-2012 08:45 AM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Insulation and furring strips question tpagel Building & Construction 6 11-22-2009 12:46 AM
Steel studs / Basement Insulation Chemist1961 Building & Construction 9 06-26-2009 02:54 PM
Basement 2x2 furring strips, basement clutter, top plate not attached to floor joists touchsuhas Remodeling 5 12-26-2007 07:01 PM
