-   -   Studs vs Furring Strips In the Basement (http://www.diychatroom.com/f19/studs-vs-furring-strips-basement-159746/)
brockmiera 10-11-2012 10:31 AM
I am on the demolition phase of my basement remodel. The basement walls right now have 1x2 furring strips vertically every 16" O.C. attached directly to the basement walls. I want to put in extruded poly probably 1" on all exterior basement walls for a good thermal break.
My question is this. Should I frame a 2x4 stud wall just to the inside of the poly or should I use new furring strips vertically to attach drywall to?
My initial thought is to go with 2x4 wall but in the interest of saving valuable square footage a furring strip application will make the wall assembly much less intrusive.
Thanks in advance for your thoughts.
sublime2 10-11-2012 10:38 AM
Frame it.
The space lose is minimal.
I would not rely on furring strips nailed to brick/ concrete to support the rock.
brockmiera 10-11-2012 10:44 AM
yeah I was leaning that way anyway.
Another question. The bathroom before has tile glued directly to the wall with some sort of superman adhesive. Once I get all of that old tile off is it acceptable to put tile back on the walls?
My original thought was to use a shower membrane like Kurdi liner on the wall then tile to that. Or should I put up the rigid board insulation - shower membrane - then tile?
I really want to do this right but framing a new wall against the exterior wall will require me to move a lot of plumbing. I have a picture too if that will help.
brockmiera 10-11-2012 10:55 AM
Bathroom Wall
1 Attachment(s)
Here is a picture of the wall in question.
drtbk4ever 10-11-2012 11:27 AM
You are referring to the tiled wall with the window? I assume it is an outside wall given the insulation and window and that is part of the shower. Is that correct?
Is it a 2X4 wall now?
brockmiera 10-11-2012 11:30 AM
Yes sir. Outside wall - no framing now. Just tile thinset to concrete wall. that window will be in the shower.
woodworkbykirk 10-11-2012 02:45 PM
framing fixes a few issues.
1) you get better insulation in the wall
2) easier to run electrical and plumbing
3) create a straight wall as opposed to furring strips applied to the foundation... telegraphs the irregularities in the wall.
drtbk4ever 10-11-2012 05:03 PM
Ouch, that isn't ideal. Could you frame any kind of wall there without impacting your plumbing?
brockmiera 10-11-2012 05:39 PM
Yeah I suppose I could go with a 1/2" Extruded Polystyrene board / 2x2 framing (or furring strips glued to the Poly board)
I'm curious to find out if anyone thinks using the 1/2" Poly Board with either a concrete board / membrane set up or just membrane would work???
brockmiera 10-12-2012 10:11 AM
So after much research I've decided to go with a 1/2" Kerdi Board product. The is a polystyrene board with the kerdi membrane already applied to it. Seems like the best of both worlds. Thanks for the feedback. I'll start posting my progress on another feed.
