Studs Too Close Together For Structured Wiring Panel - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-25-2009, 10:52 AM   #16
Rewards Points: 264
Since you are setting the boxes side by side, why not cut the middle stud out and header off the top and bottom of the cavity? Then, if necessary, run a vertical pc. of material in the middle to make a snug fit. You can easily trim around with 1x material and paint it to match the existing trim.
7echo is offline   Reply With Quote
Tags
panel , structured wiring , studs
Wiring from panel Rick N. Electrical 6 07-10-2013 05:25 PM
Wiring a Panel DigitalFusion Electrical 10 11-08-2009 12:52 PM
Main Panel / Service Upgrades gbe Electrical 12 11-07-2009 12:20 AM
Before I close walls: hard wiring under cabinet lighting with Romex. jws3 Electrical 6 08-29-2009 01:24 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 06:54 AM
