Studs & Headers - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 11:33 AM   #1
Question
studs & headers
how many studs do I need under a header that will allow for a 36 inch prehung exterior door
ralphc is offline   Reply With Quote
Old 07-02-2012, 11:50 AM   #2
If you are talking about jack studs, you need one on each side...
JonM is offline   Reply With Quote
Old 07-05-2012, 12:35 AM   #3
Registered User
Rewards Points: 5,244
Hmmm, I answered this before; http://publicecodes.citation.com/ico...002_par021.htm
Gary
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
Drywall & metal studs. meow571 Drywall & Plaster 1 11-05-2010 06:59 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
