Studs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 07:04 PM   #1
studs
Adding master bed & bath. What is the difference between yellow pine & douglas fir? Is one better than the other? Also, when comparing lumber & other building materials...who has the best quality? home depot, lowes, lumber yards...
mmccollum is offline   Reply With Quote
Old 08-06-2012, 07:33 PM   #2
Framing Contractor
Rewards Points: 78
Different lumber species are stronger than others. Many times, the box stores get lumber from the same places as the yards. If you are having it delivered, you will probably get better material from a yard. At the box stores, people tend to pick through and select the best stuff, leaving the rest for deliveries.
sixeightten is online now   Reply With Quote
Wood or Steel wall studs? dredogol Building & Construction 2 07-10-2011 08:31 AM
Making wall studs plumb and on plane laxgrandma Carpentry 1 07-06-2011 06:32 PM
Attaching a worksurface directly to studs in of a basement wall BasementVirgin Building & Construction 3 10-06-2010 01:04 PM
New foundation for bathroom floor and exterior wall studs JayG Building & Construction 2 07-11-2010 02:25 PM
using 8' studs vs 7'-9" studs RINAIL Carpentry 2 07-10-2008 05:16 PM
