Old 12-14-2012, 03:22 PM   #16
journeyman carpenter
woodworkbykirk's Avatar
Stud wall: premake vs build in place?
stick frame basement walls in renos mainly because the old slabs are hardly ever even which means you can have a huge variation in studs lengths. if every stud works out to being within 1/8" of one another you can prebuild the wall and put it up.. the only different thing i do though is the bottom plate is already fixed. the studs arent nailed to the bottom plate only the top.. stand up the wall first then hop the studs up onto the bottom plate.. doing this allows you to get the wall standing up straight first and it doesnt destroy or pull off the vapour barrier...
woodworkbykirk is offline   Reply With Quote
Old 12-16-2012, 03:07 AM   #17
Wire Chewer
Red Squirrel's Avatar
Originally Posted by DangerMouse View Post
.....and no-one caught this????? wow.... just wow.
C\_/ <---free coffee for all!
DM
Loool oops. Unless I can get the atoms to align properly so I can put studs inside of studs, that ain't happening! Yes I meant every 16 inches. When it comes the time to do this I'll measure around to see what kind of variances I'm looking at with the floor/ceiling and if everything is close enough then I'll just prebuild. Otherwise I'll build stud by stud. Some spots I may have to do it that way no matter what such as where my server rack is as it will be a tight fit to get a prebuilt wall there.
I'll probably stick with using shims though if I do prebuild, from what I read I kinda want the wall to "float" as the floor may move over time. If the wall starts lifting up the house it may not be enough to cause damage, but it will be enough to perhaps open up tiny cracks that will let air and bugs in. Then again I will be spray foaming so this is probably not an issue.
The Following User Says Thank You to Red Squirrel For This Useful Post:
oh'mike (12-16-2012)
Stud in middle of tub/shower plumbing wall. CharlieR Plumbing 2 11-06-2012 04:07 PM
build a new load bearing wall George Minor Building & Construction 4 07-01-2012 04:11 PM
how to insulate and build exterior basement wall brentschultz Building & Construction 3 02-04-2011 12:09 AM
Remove 20 inch Stud on A Bearing Wall triduong Building & Construction 7 08-03-2010 06:14 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
