Old 09-18-2007, 10:24 AM   #1
Stud strength
I'm building a 22x20 garage with storage above (using 2x10 joists). I'd like a tall ceiling and was wondering if using 2x4x10' studs will be strong enough as compared to 2x4x8' studs (for a lower ceiling)?
Thanks,
dmend
dmend is offline   Reply With Quote
Old 09-18-2007, 03:26 PM   #2
Framing Contractor
Stud strength
Thanks,
dmend
Yes, they are strong enough. 2x4 10' walls are built every day. When you file for a permit, they will let you know if they will work in your area, but I've never heard of a 2x4 10' wall not being strong enough around here.
Joe Carola
Joe Carola is offline   Reply With Quote
Old 09-18-2007, 06:48 PM   #3
Stud strength
You do need to use the correct species of wood for your application. They are not all the same.
Ron
Old 09-18-2007, 07:02 PM   #4
robertcdf's Avatar
Stud strength
Around here 10' is the limit for 2x4's on garage walls. Once you break 10' you have to upgrade to 2x6. It will most likely be the same for you but be sure to verify when you get your permit... It would suck if it was differant and the inspector makes you tear it down and use 2x6.
robertcdf is offline   Reply With Quote
Finding AC wires with Ryobi stud finder darsunt Tools 4 03-21-2007 08:43 PM
Who makes the best stud sensor? kcrossley2 Building & Construction 6 03-19-2007 12:31 PM
Best reasonable stud finder??? Sellncars Tools 6 10-03-2006 09:29 PM
Stud Finder problem... kalaniwavo Carpentry 4 02-26-2006 08:24 PM
Stud mounting on Aluminum studs DK75 General Discussion 2 02-17-2006 09:24 AM
