Stud Spacing When Installing Enclosure Not Enough - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-16-2011, 04:00 PM   #1
Unhappy
Stud spacing when installing enclosure not enough
I am installing an enclosure to have all the wiring (cat5e, rg6 , etc) all meet up in my house. I cut the hole in the drywall but the enclosure seems to be a tiny bit bigger than the space between the studs. It's a 42 inch tall enclosure. So now what do I do ?
I was thinking of shaving off the studs a little bit, what tool would I use for that ? Space between the studs is 14 inches, cabinet seems just a tad over that.
Thanks, great forum !
az_r2d1 is offline   Reply With Quote
Old 03-16-2011, 04:17 PM   #2
rditz's Avatar
so is the enclosure too wide or too tall??
also, from your description it sounds as though you are trying to sink the enclosure into the stud cavity.
what are dimensions of your box??
if you are hitting a horizontal brace, cut the nails that fasten it to your vertical studs with a sawzall and then run the sawall between it and the drywall on the other side.. it should come right out..
what is on the back side of the wall you are putting the enclosure on??
pictures...
rod
rditz is offline   Reply With Quote
Old 03-16-2011, 04:31 PM   #3
pictures...
rod
Sorry, I guess I didn't make it clear enough. The enclosure has to sit between two vertical studs (sunken in , like you said). The enclosure is 14 1/8 inches and the stud space is exactly 14. It's very ridgid.
No horizontal studs there.
The backside is also drywall.
Attached are some pictures.
Stud spacing when installing enclosure not enough-img_20110316_132740.jpg   Stud spacing when installing enclosure not enough-img_20110316_132759.jpg
Old 03-16-2011, 04:58 PM   #4
I ask the impossible!
Rewards Points: 640
I think I'd have to go with a belt sander on this one.
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 03-16-2011, 06:26 PM   #5
Personally I'd use a circular saw, set to maximum depth, and a hammer n' chisel.
VIPlumber is offline   Reply With Quote
Old 03-16-2011, 06:36 PM   #6
Not a bad idea ! Thanks.
Would a oscillating multi tool work as well ?
Old 03-16-2011, 06:48 PM   #7
kwikfishron's Avatar
Rewards Points: 170
I’d filet it with a Stihl but that’s just me.
EDIT: Don't try this at home!
kwikfishron is online now   Reply With Quote
Old 03-17-2011, 09:42 AM   #8
rditz's Avatar
the circular saw is going to get you closer sooner than anything else.. the problem is that the depth of the 2x4 is greater than the depth of the cutting ability of the saw...
i would consider the next stud cavity to see if it has the space in it... if the studs are truly on 16" centres, then you should have 14 1/2" between them, leaving enough space for your box. I think that the cavity you are working in is smaller because it is at the end of your wall or they are shy of 16" centre.
rod
Old 03-17-2011, 10:04 AM   #9
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Before you go sanding & shaving, oscillating and chainsawing, take a scrap of 2x4 and cut it to 14-3/8".
Set it inside the cavity at an angle and beat on it to spread the studs.
You should get a screw 'pop' but just remove the screw, reinstall and mud.
There's always a little play in a single stud.
Like rditz says....16"o.c. should leave a 14-1/2" cavity
tcleve4911 is offline   Reply With Quote
Old 03-17-2011, 10:08 AM   #10
rditz's Avatar
i like that approach... do this top and bottom, should work
The Following User Says Thank You to rditz For This Useful Post:
tcleve4911 (03-17-2011)
Old 03-17-2011, 10:15 AM   #11
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Looking at your profile pic with the dozer, I knew you'd like the "beat on it" approach.....
Get me my persuader.......
Old 03-17-2011, 10:27 AM   #12
rditz's Avatar
although not a professional contractor, I do a lot of different things...
I actually bought the tractor not running after it had been stored for 6 years and had it operating within a few weeks...
I have had to be creative from time to time and always like to learn new "tricks" to accomplish the goal at hand... this site is great for that and also seeing what NOT to do..
thanks
rod
Old 03-17-2011, 04:43 PM   #13
Remodeler
JCarsten's Avatar
Yes- the ole' "hammer-saw". If you only need to go 1/8", this is your best bet.
JCarsten is offline   Reply With Quote
Old 03-17-2011, 05:09 PM   #14
Rewards Points: 170
Sure you can always beat it in if you donít mind a little drywall repair.
Old 03-17-2011, 06:23 PM   #15
Rewards Points: 194
If you could get your hands on a 3.5" router bit, that could work. That is, if you could control the router.
loftezy is offline   Reply With Quote
Tags
enclosure , space , stud
Stud spacing above a fireplace in an older house? What's going on? CoconutPete General DIY Discussions 13 01-28-2011 06:42 PM
Installing washer and dryer in basement in former tub enclosure. dj_backq Building & Construction 8 11-02-2010 09:56 PM
Installing washer/dryer in basement in former tub enclosure. dj_backq Carpentry 1 10-08-2010 12:09 PM
Stud spacing... dstylez Building & Construction 4 03-12-2009 03:09 PM
Joist, rafter, and stud spacing for shed? Badfish740 Building & Construction 2 10-27-2008 05:12 PM
