Old 03-12-2009, 12:47 PM   #1
Question
Stud spacing...
So here's a newbie question...I've been spacing my studs 16" o.c...but there are some cases where the stud might be bent due to warping or the stud moved slightly as I was toenailing...is that a big problem if in someplaces the spacing between the studs is off by within an inch?
dstylez is offline   Reply With Quote
Old 03-12-2009, 01:30 PM   #2
gravity always wins
Stud spacing...
It could be when you go to hang drywall or sheathing on it. The edge of a sheet falls on only 3/4 of an inch to begin with. WIth a stud that's off an inch and warped to boot, you may miss it completely. Take a piece of 2x4 cut 14-1/2" long. Lay it between the studs as you toe nail one side only. When you have all the studs set, go back the other direction and toe nail the opposite side. They won't shift around as much that way and you'll have a better chance of preserving your 16" centers.
Old 03-12-2009, 02:12 PM   #3
Stud spacing...
^ that's a great idea..I'll try that..thanks!
Old 03-12-2009, 02:13 PM   #4
Stud spacing...
You shouldn't intentionally vary the spacing because at the very least it can be a source of aggravation trying to find studs where they should be but aren't.
That being said, if they are interior nonload bearing walls then you might get by not fixing it. Some folks use 24" spacing so an occassional 17" space instead of 16" should be fine structurally. Some drywallers actually like to float the butt ends between the studs so hitting the edge with drywall might not be an issue (check with your drywaller). But they won't like trying to find the irregular spacing with their drywall screws in the field. If you're doing the drywall yourself you can quickly mark the stud locations. If you aren't floating the ends you can just work off the stud spacing as it is and probably have one extra cut per row per wall (and a little more waste).
If they are exterior walls then fix then so your sheathing fits. If they are interior load bearing walls then fix them because the load bearing characteristics of the wall were based on 16" centers.
Old 03-12-2009, 03:09 PM   #5
Stud spacing...
None of them are load bearing walls. Most of them are all within 0.5" off if anything..I dont think any are upto 1"...
Plasma TV Mount problem - one of the 4 screws cannot hit a stud..... wasserkool Home Theater 4 01-05-2009 09:24 PM
Grout Color Choice / Spacing jamiedolan Tiling, ceramics, marble 11 12-25-2008 03:00 AM
Joist, rafter, and stud spacing for shed? Badfish740 Building & Construction 2 10-27-2008 05:12 PM
Please, help with sheathing and stud placement Mrmusic Building & Construction 2 09-10-2008 05:52 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 01:28 AM
