Stud Locations And More In Bathroom - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-02-2011, 10:19 PM   #1
stud locations and more in bathroom
While looking for studs in the bathroom I was picking up something in the middle of the wall. At its narrowest it is 7" tall and at its widest it is 15" tall. Is this "blocking" or am I picking up something else?
Shown in the pictures are the stud locations, the horizontal area where I am picking up something, and the cheap electronic Stanley stud finder that I was using.
I'm putting up towel rods, and if there is wood behind there I wont use plastic anchors, I might use these metal anchors that go through drywall only or drywall with a stud behind. Or maybe just wood screws. Should I stab something small into the wall at the same point where the anchor will go to see what is behind there?
djgrant is offline   Reply With Quote
Old 08-02-2011, 10:46 PM   #2
Rewards Points: 150
If there is no plumbing in that wall just use metal screw in Sheetrock anchors. That way is doesn't matter what is back there, it will go in. I bet it is that crappy stud finder lying to you. I don't know why anything that shape would be in a wall.
Broughton is offline   Reply With Quote
Old 08-03-2011, 05:16 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
looks as tho the top line of the green tape could be blocking, as for the lower tape line looks like an electric line for the other side of the wall, or a plumbing pipe. just my 2cents
Old 08-03-2011, 05:17 AM   #4
kwikfishron's Avatar
Rewards Points: 816
I think you should stick the screw that came with the mounting hardware into the stud and be done with it.
kwikfishron is online now   Reply With Quote
Old 08-03-2011, 07:13 AM   #5
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Most towel bars come in 18", 24", or 30". If the studs are 16" OC the best case is they'll still have to use a drywall anchor on one end
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 08-03-2011, 07:28 AM   #6
Not so new
12penny's Avatar
Rewards Points: 520
You're making way more out of this than you need to. Put it where you want it. If theres wood behind it ...fine. If not use an anchor.
12penny is offline   Reply With Quote
