Stuck Tilt In Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-24-2009, 05:47 PM   #1
Hello,
I have vinyl tilt in windows in my new home. I was tilting them in this weekend to cleanthe external pane and the lower pane on one of the windows got stuck after being put back in the sash. It will not move up or down more than an inch. Any ideas? Thanks
cs006b is offline   Reply With Quote
Old 08-25-2009, 06:04 AM   #2
The window sits in guides at the bottom sash corners. If the support pins are not seated in that guide, the guide block will not slide in the track. Tilt the window out, make sure the pins are sitting fully in the both guide blocks, then tilt back in. That should fix it.
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 10:47 AM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 05:29 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
