Old 11-29-2010, 02:58 PM   #1
stucco in winter?
Hi there, I have two questions about stucco.
1. Is there any simple rule I have to follow to put on stucco in California winter? Like no rain after a couple of days...
2. My house is covered by paper and metal lath. How long can the paper last before it be damaged by UV and rain? (How soon should I put on scratch layer?)
Thanks a lot!
pttcc is offline   Reply With Quote
Old 11-30-2010, 12:49 AM   #2
stucco in winter?
If you haven't yet, I'd suggest you read about stucco on greenbuildingadvisor.com before you do anything. It is discussed there often, and there may be some things you should consider before applying it. j
The Following User Says Thank You to jklingel For This Useful Post:
pttcc (11-30-2010)
Old 11-30-2010, 12:55 AM   #3
jlhaslip's Avatar
stucco in winter?
San Diego? or Sierra Nevada?
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is offline   Reply With Quote
ledger stones on stucco wall, but wall is bowed rrauenza Building & Construction 7 05-18-2010 06:38 PM
Questions about painting and possibly adding siding to stucco house? krm27 Painting 3 01-19-2010 01:22 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 04:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
Stucco leak (long post) Pat B. General Discussion 1 03-24-2006 07:54 PM
