Stucco - Window Popouts & Water - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-19-2010, 01:55 AM   #1
In Arizona they install "pop-outs" around the windows. My question is if these pop-outs need to be sloped away from the window in order to prevent water intrusion through the window frame areas?
I have some pop-outs that are NOT sloped away (they are level or actually sloped towards the window) and I don't know if these will pose a problem in heavy rains. I caulked around the windows but I don't know if that is enough.
JackOfAllTrades is offline   Reply With Quote
The Following User Says Thank You to JackOfAllTrades For This Useful Post:
hroberts (01-25-2012)
Old 02-19-2010, 07:22 AM   #2
Not sure what a 'pop-out ' is. A pic would help some of us. But if it is a normal architectural feature, I would have to assume that it is correctly done. With proper flashing safequards, caulk is just an extra safety measure.
Old 02-19-2010, 09:46 AM   #3
anything sloping water back to window not so good me thinks, dont care what its called
The older I get the better I was
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
