Old 08-11-2009, 02:57 PM   #1
stucco underlay/wrap
am in the process of prepping two 18"x18" x 7 ft high pillars for a traditional 3-coat stucco job.
The pillars are 6x6 posts boxed out with OSB sheathing. My question is should I wrap the pillars in
a) 15# roof tarpaper
b) 2 layers of Grade D building paper
c) Tyvek Stuccowrap ($$$ and thicker than I may have planned)
I have seen all 3 discussed with positives and negatives and I am not quite sure which way to go. Regular self-furring galvanized metal lath will go on top of this - and then scratch, brown and finish coats of stucco.
Also while wrapping the pillars there will be a few obstructions to work around (porch rails and supporting headers) - so ease to work with is a factor and I am also curious about recommendations for flexible flashings (vinyl).
mlupa is offline   Reply With Quote
Old 08-12-2009, 11:01 PM   #2
Professional Wood Shafter
ryanh's Avatar
I've always wrapped all my details in typar/tyvek paper. Never had a problem. Then again I always have a roll or some scraps around, if you need 10 feet i wouldn't go buy a 75' roll
ryanh is offline   Reply With Quote
Chimney Stucco Repair mikeyboy Building & Construction 7 04-11-2009 12:33 PM
Vinyl siding and stucco. PrairieStudent Building & Construction 4 08-29-2008 04:03 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 05:46 PM
color streaks on new stucco homeowner in Minnesota Building & Construction 2 08-11-2008 08:07 PM
couple of q's on stucco exterior joeyboy Building & Construction 7 05-19-2007 11:04 AM
