Stucco Transition From Wire & Paper To Block Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 10:39 PM   #1
Stucco transition from wire & paper to block wall
Hello, I am enclosing my patio and am going to stucco the outside. there is a block wall about 3 ft high, then sheathing above that so I will have paper and wire on that portion.
My question is can I stucco from the wire onto the block wall or am I going to have a cold joint/crack there?
Also part of the wall has paint on it?
Do I need to apply lath to the block wall and if so how would you attach it?
Thanks, Joe
jmk909er is offline   Reply With Quote
Help getting paint off block wall butchbs1985 Painting 4 06-09-2011 08:20 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-06-2009 12:02 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
